You can get the CA in the orderless type and it comes in three different thickness with longer cure times. For the thin I like those long thin tips so I can just use A drop or two where needed. The stuff is sometimes A thrill to sand, like always. I use about 6 different types of glue during A build but mostly CA. If you come down with A cold that won't go away stop using the CA or open A window close to you. It can cause problems with your health.
Looks like A fun build!
I mostly build from MAN and RCM plans but Raindave sent me some plans A while back of A couple of old pattern planes I have to get to in the next year or two.
So many planes and so little time and money.
