RE: Engine causing servo glitches
Dude before you go buying stuff try seperating ignition cables battery isolate the radio stuff on one side of the plane and the radio stuff on the other side and get plastic cable isolator from autozone and make sure you do'nt have broken cable wires from servos or extencions and make sure your reciver has a pice of foam under it and tied down.the problem has to be some where I sure of it.it sure beats buy a new radio and reciver and what if you buy radio and reciver and still glitches after all???
