RCU Forums - View Single Post - BVM pipe help needed
Old 09-20-2007 | 12:21 PM
John Redman
My Feedback: (8)
Default RE: BVM pipe help needed
I would be leary of using a BVM puffer pipe on an OS 91. The pressure system is different and it may make needling the engine very difficult, mayeb even to the point you might go lean in the air and smoke your motor. I have no experience with it on other engines, maybe someone here does.
i will say if it doesn't fit tight, it won't seal and you won't be able to needle the motor at all.
