RCU Forums - View Single Post - Bluejay Kits
Thread: Bluejay Kits
Old 09-20-2007 | 05:54 PM
dbacque
Default RE: Bluejay Kits
I assume you mean 3% aileron mixed with rudder and 2% elevator also mixed with rudder.
Is the aileron mix with or against the rudder direction and is that an up or down elevator mix.
No, I've got rudder to aileron and rudder to elevator mixes set up. When I move the rudder a given amount, the ailerons move 3% as much and the rudder moves 2% as much. But the exact terminology of the mix might depend on the radio brand.
I'm not positive on the directions of the mix. I pretty sure that the rudder to aileron mix is left rudder to left aileron to correct a slight roll towards inverted. I'm not certain but I think the elevator mix is up elevator to correct a very slight push to the belly.
Both of the mixes are very minimal, I flew the plane for better than 6 months before bothering to set up any mixing. Flying knife edge without the mixes was not a problem. But it sure is sweet to have rudder only knife edge now!
Dave
