RCU Forums - View Single Post - Lanier Edge 540T - PROBLEM SOLVED
Old 02-27-2002 | 11:23 PM
matlok's Avatar
matlok
Default Lanier Edge 540T - PROBLEM SOLVED
Same problem here - I managed to widen the hole through the servo openings with a Dremel, and used inner nyrod as a guide for the cable. It still bent the cable slightly so I never could tention the cables properly. You might be able to get a little bit of a straighter shot by crossing the rudder cables. Mine crashed before I got to try it. :cry: BTW, check and reinforce if necessary the nose/firewall! I (we) are pretty sure it went in b/c the firewall or something in the nose came loose (long story...) Good luck!
