EASY START programming for Ignition of MVVS 58
Hi all,
Need your help. I got MVVS58 and ignition module S-Standard. I read the instruction manual for EASY START function and preignition curve. I do not understand what is the purpose of this function? Can I use Ignition MVVS 58 as a normal like for DA-50 or 3W. That is just plug power supply 7.4 volts 2600 mAh LI-ON and sensor and LED per instruction but do not do EASY START FUNCTION. What I have to be careful if I do not use EASY START function. Right now I installed CHOKE SERVO to OPEN and CLOSE the choke valve and commanded by RADIO GEAR FUNCTION.
Please advise.
