RE: Problem Getting Fuel into DA-50 Engine
The flappers in the fuel pump side might be stuck. Try squirting a bit of fuel into the engine and start it. The engine might draw fuel hard enough to release the flappers. Also try priming it with your thumb over the intake and spin the prop. If that makes the fuel flow enough to start the engine but not sustain it while running then a carb rebuild is in order.
