RE: SPE 40cc
There is absolutely no mystery attached to getting your SPE 40 to run well, or does it need any longer than usual break in time. Just be patient with it and follow all the advice and suggestions that you have been given, and it's more than likely you will end up with an engine that is easy to start, relaible and a good performer. So many before you have found it to be so, it should be no different for you.
Karol
