RCU Forums - View Single Post - Tips needed for rudder input.
Old 02-27-2002 | 12:02 PM
Ed Smith
Default Landing
It is quite likely that all of the control surfaces will be used while landing. So be ready.
It was best explained to me this way. When landing use the engine to control altitude and elevator to control speed.
If you think about it it makes sense. If the engine is shutoff you will lose altitude no matter what you do with the other controls. So if you are losing altitude give it some more engine and the airplane will start to climb.
If you are coming down too fast give some up elevator, the nose will lift and the airplane will slow down. It will not climb because you are throttled back.
Try to avoid using aileron while landing, for steering you should use rudder. Aileron input at slow speeds can cause a wing to drop and not be recoverable close to the ground.
There is a starting point for you.
Ed S
