RE: F-5 Cat. Plans prototype build.
Shocker.
I will be using two Speedmaster Stinger Struts
And i have a idea to make then adjustable by rc. They adjust by a screw rite, Well i will be soldering on a .098 flex shaft to the head of the screw and then run it into the boat and to a servo that has been modified to rotate all the way around. So this way the flex shaft will run on teflon threw the hull and to the screw and drive the screw up and down VIA modified servo. there fore adjusting the the trim of the boat!.
i havnt decided to use two servos or just one and use a gear
