RCU Forums - View Single Post - Nitro models pusher Bobcat?
Old 09-24-2007 | 01:23 AM
  #2203
opjose's Avatar
opjose
Default RE: Nitro models pusher Bobcat?
ORIGINAL: tamir_250
hey everybody !
which engine will be better for the FALCON 120, the AX120 or THE FX 160 ?
regurds.
With the Falcon, what you are looking for is PITCH SPEED.
The Falcon 1.20 has a lighter wing loading than the Bobcat .52.
Hardware wise they both have the same weight in servos, etc, but the Falcon has a bigger wing area.
I would assume that both engines will work. The FX 160 may give you better verticals, but the AX120 when combined with the right prop mayl unload in the air a bit better due to it's lower mass.
Add to that the lighter weight of the AX 1.20 and you could go either way.
I'm planning on putting in a 1.20 in mine and using high pitched props.
My Bobcat .52 SCREAMS with the GMS .76 engine.
A few Turbine guys commented that "I should have gotten one of those to learn how to fly the Kingcat type planes, using the Bobcat as a jet trainer... ".
