RCU Forums - View Single Post - Engine causing servo glitches
Old 09-24-2007 | 09:29 AM
Lemjim
Default RE: Engine causing servo glitches
Hello,
Have you solved the problem yet? Im having the same problem with a Fuji BT-32 EIS mounted in a new Giant Super Sportster, all surfaces glitch but the throttle really go nuts, I have moved the throttle servo back past the fuel tank and the ignition battery and switch way foward with no luck, my module is still mounted to the firewall above the engine with screws (will soft mount this next) other than that Im at a loss.This is my first gas plane, but have set up many others with success.
Thanks, Jim
