GP 60 Cub Float attachment
Im currently building GP 60 size floats for the GP 60 size cub. the float manual does not cover how to attach the forward float attachment to the fuselage. Should I mount it the same as the rear and drill more holes in the Plywood landing gear mount plate? Or is there a way to utilize the holes that the aluminum gear mounts to and plug the other holes that do not get used to keep water out of the fuse? any and all suggestions are appreciated
