RE: F18F Skymaster ARF Plus
Same as the old one. CG at 130 - 135mm for the first flights will give you the most stable flights. You may move the CG back later, I have tryed it on the old model all the way back to 150mm. It gets a bit sensitive at 150mm so first start at 130mm.
Michel
