 F18F Skymaster ARF Plus >
Old 09-25-2007 | 03:43 AM
Default F18F Skymaster ARF Plus
Hello,
Has anyone already flown the new F18F Skymaster Arf Plus?Which CG and throws are the best?
Thanks a lot.
Old 09-25-2007 | 01:13 PM
JetsRC's Avatar
Default RE: F18F Skymaster ARF Plus
Same as the old one. CG at 130 - 135mm for the first flights will give you the most stable flights. You may move the CG back later, I have tryed it on the old model all the way back to 150mm. It gets a bit sensitive at 150mm so first start at 130mm.
Michel
