ORIGINAL: bruce88123
ORIGINAL: TxDiveBomber
Definitely make sure your RX battery is fully charged. Charge it for 24 hours the first time new out of the box and monitor it carefully. If it goes low on you in flight the RX will reset and leave you w/o a RX for almost 5 seconds and a lot can happen (nothing good) in that time. A 6v pack or higher capacity 4.8v RX pack is becoming common with Spektrum systems in the field.
I did say
"ALMOST", I did not say
ALWAYS. And there have been complaints of it taking nearly that long here in the forums.
True you did say Almost. You also said “a lot can happen (nothing good) in that time”. Leading the reader to believe it’s going to take 4-5 seconds to reset “almost” every time. I’m just saying from my experience as a person who fly’s using a Dx7 that’s not the case. At least with my radio or the one in flight reset I’ve seen. No reason to take it as a personal attack I simply disagree with you. The complaints I take with a grain of salt. I'm sure you've had a radio hits in the past. Most 72 MHz radio hits I’ve had lasted less than a second but it feels like an eternity.
