Remote sensitivity with Cline?
If this is your first 4-stroke engine you might find it a bit easier to initially byppass the Cline system. Use Muffler pressure and you will find the high-speed needle adjustment works differently.
After the engine is setup with muffler pressure you could then switch to the Cline system.
