RE: Another covering question
Just for future consideration: I had to remove all of the covering on a plane I had. It was the shelf paper kind of covering.
When you peeled it off it left the glue residue a lot of the time. Finally, decided to try paint stripper. I sprayed a heavy coat on the covering on the fuselage.
Took a scraper and removed the covering and 99% of the residue quickly and easily.
Used acetone to remove the smll spots left. Wiped it down with acetone, sanded lightly with 400 grit and I am in the process of recovering now.
No problems, thus far.
