RE: Don Dewey Wayfarer
Ok, I traced the wing and drew a laser cut file for the ribs. I have ordered four sets of laser cut ribs. They are for the original size (not enlarged). I can let you know the cost when I get the invoice. One is mine and one is spoken for. That leaves two sets if anyone wants one. I went back to the original construction method with full-depth notched spars. I made all the ribs the same to keep it simple. The center ribs will need to have the spar notches enlarged 1/16" for the ply dihedral doublers and the ailerons cut away as described on the plans.
David
