RE: Comp Flash Throws????
Peter,
I am running exactly the movement they recommend on the elevator but with 50% expo. However, 3-4 friends have flown mine and some found the elevator a little too powerfull for their taste. Once I clicked in 80% rate they were much happier so if I were you I would setup the rate to have 100% on top rate and 80% on low rate so you have the choice.
Also like Dave I use less flap than they specify for take off and landing.
Either way you will have a great flying plane!
Geoff.
