 Comp Flash Throws???? >
Old 09-27-2007 | 02:17 AM
Default Comp Flash Throws????
Just picked up a Comp Flash, and wondering what control throws to use.
I was told as little as 5mm on Elevator with 30% - 50% expo, is this correct????
Regards
Peter
Old 09-27-2007 | 02:43 AM
Default RE: Comp Flash Throws????
Peter
No!
The standard movement is OK but with 40-45% expo on elevator
I use less flap than they state for take off and landing
Dave Wilshere
Old 09-27-2007 | 03:01 AM
Geoff White's Avatar
Peter,
I am running exactly the movement they recommend on the elevator but with 50% expo. However, 3-4 friends have flown mine and some found the elevator a little too powerfull for their taste. Once I clicked in 80% rate they were much happier so if I were you I would setup the rate to have 100% on top rate and 80% on low rate so you have the choice.
Also like Dave I use less flap than they specify for take off and landing.
Either way you will have a great flying plane!
Geoff.
Old 09-27-2007 | 03:37 AM
Peter
The situation with the Flash and to a lesser degree with the Lightning is that the elevators are very powerful.
To get a balanced control response you need more expo on elevator than aileron.
I fly without rates chosing to use Expo to get a nice smooth aeroplane with small movements and still have the full movement for snaps etc (positive with the Flash/Lightning)
Like Geoff says if you have 80% available you can experiment.
Dave w
Old 09-27-2007 | 06:51 AM
My Feedback: (51)
I setup mt friend's flash as most people recommended, just like in the manual for the maiden. should fly soon and then we'll see if it needs correction.
Old 09-27-2007 | 07:00 AM
jonkoppisch's Avatar
My Feedback: (162)
ORIGINAL: turbinepeter
Regards
Peter
According to the manual, it takes 18mm up and down for normal flying and 20-25mm for takeoff and landing?? I have mine set to the manual but haven't flown it yet???
Old 09-27-2007 | 10:18 AM
Dave, Geoff
Many Thanks for the info.
Incidentally, the Flash I got hold of was flown at St Athan, but unfortunately had a bump with a landing light!!!!!!!
It is now fully repaired, although not mint!!!!!!
Thanks Again.
Peter
Old 09-27-2007 | 10:45 AM
Peter
Watch that wing it was smashed back to the spar and will need strengthening as the D box adds to the strength.
Dave
Old 09-27-2007 | 11:25 AM
Dave
Thanks, I did the repair!!
When I first saw the wing, i thought it was not worth repairing, but it was not as bad as it looked. Yes, It was back to the main spar, but with a huge chunk of High Density foam, Glass Matt, and Epoxy, it is now looking more like a wing!!!!
Looking on the Comp site, made me decide to repair, as the cost of a new wing made me cry!!!! It is more than the cost of the Fuzz.
Hope to test it out nxt week.
Hope it holds out??? You may just get a call for a new Flash!!!!
Peter
