RE: Tower Fun 51 trailing edge
What you explained is what I am used to seeing, but in this case the trailing edge is smaller than the rib end. So when you sheet over the trailing edge and onto the ribs there is a 3/32 inch gap. I addressed the problem by substituting a different piece of stock that was the same size as the end of the rib. Once I do some shaping it should be fine. Thanks for the suggestion.
Doug
