RCU Forums - View Single Post - Crashed and not exactly sure why
Old 09-27-2007 | 10:03 AM
  #37
MinnFlyer's Avatar
MinnFlyer
Default RE: Crashed and not exactly sure why
ORIGINAL: griesel
I initially set it up for minimum mechanical throw. In close at the servo and way out at the horn. The elevator and the rudder did not
have enough travel so I ended up moving the elevator one hole in at the horn and two holes in at the rudder horn.
It would be much better to move OUT on the SERVO end than IN on the CONTROL HORN.
By doing it the way you did it, you're losing your mechanical advantage - which could lead to flutter.
