RE: How do you Tach?
No matter what you do, taching in ground effect is not the same as what is happening in clean air. So why bother. Theoretically, you know the rpm per volt of the motor and the gear ratio so if you really have a need to be a rocket scientist, do the math. If not, just go fly!
