RCU Forums - View Single Post - why not c a
Thread: why not c a
Old 09-27-2007 | 02:15 PM
bzyguy01's Avatar
bzyguy01
Default RE: why not c a
ORIGINAL: Nathan King
I used CA on my first canopy. [:@]
It REALLY fogs the plastic. Even the airborne CA "vapor" can fog the parts.
If you use normal CA it will fog the edges with the vapors.. BUT,you can use foam safe CA in this application as it is odorless and is about 90% less likely to fog the canopy...Preferrably I would use small micro servo type screws if there is enough meat on the canopy otherwise I use Foam Safe all the time on my models....I have over 50 Models right now and have used this CA method ALOT. Its soo much easier to use the odorless /Foam Safe CA and then spray it with accelerator...Just like that your done!
ID:	771386   Click image for larger version
