RCU Forums - View Single Post - Beechcraft Baron - control horn issue
Old 03-23-2003 | 01:45 AM
Fly RC II
Default Beechcraft Baron - control horn issue
Thanks Bill!
The angle of the controls surface LE (underneath the control surface) back to the horn is 45 degrees because I used a 3/8 piece of balsa stock. This is not an aerobatic ship and doesn't need the procession throw (or differential throw) as one would expect, so I'm going to position the horn back somewhat and make some fine adjustments using the servo horn (moving it forward) as the control horn is moved aft. I think that should it.
