RE: alpha 40 wing twist help..
Sure the wing is twisted or is it an aileron? Can you just adjust an aileron clevis and recenter your trim? If it was that bad when you got it you should have had it replaced back then. A bit late now. Is a crooked rudder making you compensate with ailerons? Just offering possibilities.
