 alpha 40 wing twist help.. >
Old 09-27-2007 | 06:07 PM
Default alpha 40 wing twist help..
hi guys!!my alpha 40 has a twist in the wing,its been like that since i bought it.i have to have the trim all the way to the right for the plane to fly straight.how can i go about fixing the problem?
Old 09-27-2007 | 06:17 PM
Default RE: alpha 40 wing twist help..
Sure the wing is twisted or is it an aileron? Can you just adjust an aileron clevis and recenter your trim? If it was that bad when you got it you should have had it replaced back then. A bit late now. Is a crooked rudder making you compensate with ailerons? Just offering possibilities.
Old 09-27-2007 | 06:23 PM
im sure its the wing..if i place 1 half on a flat surface and then do the same to the other side you can see that there is a difference..the hobby shop that i bought it from might replace it for me,ill talk to him this weekend.the plane wasnt bought all that long ago..
Old 09-27-2007 | 06:26 PM
It's worth asking or maybe they can show you a remedy. Hard to do without actually seeing it up close.
Old 09-27-2007 | 06:59 PM
Twisted wings are often said to be warped. When they are covered with Monokote or Ultracote, you can often remove the warp from the wing. It's often fairly easy to do.
You need a covering iron to do it.
Block the wing at the root so it's held solidly. At the tip, twist the wing the opposite to the warp. The covering will wrinkle. While holding the wing so the warp isn't there, use the iron to remove all the wrinkles. When all the wrinkles are gone you can release the wing. The warp just might be gone. If it isn't then repeat the process. Sometimes you have to overtwist.
It's a technique that all of us can learn and most already have.
Old 09-27-2007 | 08:23 PM
OzMo's Avatar
what DaRock said ...An iron might work but you 'll do it easier with a monokote heat gun. Heat up both top and bottom of the "twisted" wing and put in opposite twist ...more than you think will do the trick.... an extra pair of hands helps. hold the well warmed wing in place with opposite warp until cooled . recheck by visually siting the wing center (bottom) and compare to wing's outboard (bottoms) reheat and twist if needed. Having the bottom of the wing tips a little "up" equally is called washout and is helpful on flat bottomed trainer wings.
good luck!
Old 09-28-2007 | 08:15 PM
thanks for the info guys..the local hobby shop would have gave me a new wing if i wanted to wait a week for it to come in(didnt like that idea)so they gave me a free heat iron which did the trick,the wing is perfect now..thanks again..
Old 09-28-2007 | 08:36 PM
Great.
Old 09-28-2007 | 11:16 PM
OzMo's Avatar
Free is a good price
enjoy
Old 09-29-2007 | 07:51 AM
acarter's Avatar
That's one good hobby shop you got there!
Austin
