RE: How do you Tach?
I use one of those tachos' as well. I spool up and hold it under the main rotor blades facing up with the pitch at very slightly negative. Since I fly only in governor mode the headspeed should be the same at all times.
I think a tachometer is a must. It's the only reliable way to see what YOUR motor/pinion combination is producing.
