ORIGINAL: Da Smak
You sound like you want to drive the way I do, so in that case I suggest, you stiffen the shocks up with the white springs and possibly 40-45 wt oil, try 5k-10k-1k in the diffs and get some long spike tyres like the Hobao Angle spikes, all 3 of these measures will get you mor grip on a hard packed slippery dusty surface. You could also just attack the corners with a little less speed and in turn you can start the exit a little earlier meaning you'll be at a higher speed earlier than you competitors down the following striaights.
Thanks guys, so the thicker oil in the back will give me more drive to the rear wheels ?? will this stop my front tires balloning almost twice ther size down the straight? is the 5k-10k-1k going from the back or ie, 5k back 10kmiddle, and 1k front.
Thanks.
Steve
