RCU Forums - View Single Post - ModelTech Magic RX and Battery Location?
Old 03-23-2003 | 07:54 AM
bwillhite
Default ModelTech Magic RX and Battery Location?
I cut some out of the throttle servo hole and moved toward the right-hand side of the fuselage, that did the trick.
It took 2 3/4 oz in the tail to balance the plane, forgot to check the lateral balance, will do that tomorrow.
How did you mount your engine? I mounted this one at about a 45 degree angle to the right. I have seen picture will the engine tilled about 135 degrees to the right and the muffler underneath the fuselage. Should I change the engine around? I really don't want to.
Thanks for the replies!
bwillhite
