ORIGINAL: Da Smak
Firmeing up the rear suspension stops it sitting down when you hit the gas and so the fronts are forced into getting more traction. Diff specs are always given - front center rear, the 10K in the center will stop the tyres balooning so much, but you can always go for firmer foam inserts too.
Thanks, getting the diffs out now, so lighter oil in the back it is, also will firm up the shocks,
Cheers guys
Steve.
