Kcripto.....Badd *****! I like! I also like the way you drilled some weight off of your mount....
4 more flights today and I'm finally done and going to leave it alone now
The Oscilating Perry pump was the fix....without a doubt. Temps came down and the engine produced a very light hint of a smoke trail at long wide open passes at max temps that never exceeded 285Deg w/ 25% Cool power. The MPH's were a consistant 122-124 MPH and it didn't gain anything except hotter temps with 30% heli. I'm also going to stick with the 15X11 APC. This prop also helped keep the noise level down when compared to the 16X10 that had the tips going supersonic. I'm happy for now. Where were you Aerozona??
Shayne
