RCU Forums - View Single Post - Scratch build from plans vs. kit build
Old 09-30-2007 | 08:12 PM
outacontrol41's Avatar
outacontrol41
My Feedback: (9)
Default RE: Scratch build from plans vs. kit build
ORIGINAL: TLH101
ORIGINAL: JCOKEEFE
If not, what method(s) are used to determine the amount of
sticks, sheets, blocks needed for the project??
Thanks.
That's where lots of building experience comes in handy. Most plans designers assume the builder has a lot of experience at building. Lots of common building methods are "assumed" and not explained on a set of plans.
For sure. I try to keep the popular sizes on hand at all times...I.E. 3/8'' square balsa sticks, 1/8'' balsa sheeting, 1/4'' ply just to scratch the surface. I look the plan over and make a list of the wood shown that is needed. Not all areas of the plan are labeled with wood size so I whip out the handy ruler and simply measure. Then I go make my wood order on top of the wood I already keep in stock. Nothing worse than having to stop a building project when you're on a roll and have to wait a few days for a wood order to come in.
