RE: Engine causing servo glitches
Went to a jet rally this weekend and picked up a 2.4 setup and that took care of the problem, not the way I wanted to go but it worked. I'm also going to ground the plug as you did to clean up the air around the plane, this is so bad it could leak over to others if thats possible?
Thanks for the info, Jim
