RE: CPLR new plane OSMOSE
Well, I got to fly it again bit at sea level this time, and it feels different, after removing the Velocity Stack it became a different motor, unlimited vertical at just above half power, so the 160 is more thatn enogh fr this ship, I will try the 170 whenever I can get one, but really not needed in this conditions.
I also have to remove the THR-RUD mix, really not much improvement, and once you touch the rudder it stays in that path, so only 1% down elve on right rudder is needed.
I'm finally getting used to it, and keep reducing elevator throw and adding more expo on the rudder.
Regards
