RE: Joining Large Wings
you can stand it on end with a weight on the top wingtip kind of up against the wall sort of thing.some wings have a tapered incidence in them so to speck the top has no incidence and is flat while the bottom has an incidence taper to it.what do the instructions recommend?i use 30 minute epoxy if everything fits right and won't take long to set up in position to setup.after that use 4 ounce glass cloth and epoxy to wrap the center section of the wing all the way around the center joint.two inch wide should be big enough
