RE: Joining Large Wings
I think there is a pretty easy way. Using 30 min epoxy to give yourself time, glue the necessary areas and pieces and slide it all together. Wipe off the excess epoxy and then attach masking tape from one wingtip to the other. The tape will only touch the wingtips on the top of a normal wing. Now if the joint is correct put some tape across the joint to hold everything in place. Finally tape wingtip to wingtip on the bottom of the wing. It will suprise you just how much pressure you can generate by taping from one wingtip to the other. Good Luck.
