RCU Forums - View Single Post - Mini Titan thread
Old 10-02-2007 | 01:51 PM
  #61
BarracudaHockey's Avatar
BarracudaHockey
Default RE: Mini Titan thread
Mid or standard timing is fine.
Thats not an alarm light, it should blink then come on steady, that means its good, if its flashing slowly (1 flash / sec) then the single wire isn't plugged in right or the radio isn't setup correctly. If its flashing 2 flashes that means its getting a rudder or trim input, if its off it means its in rate mode and if its on steady that means it booted correctly and is in heading hold.
