RCU Forums - View Single Post - motor over heating ?
Old 10-03-2007 | 12:25 AM
mrasmm
Default RE: motor over heating ?
it could aslo be if you've got a bit of flight time on the motors it could be the one motor is failing. Alot of times when the motors fail they start getting hotter. if not you might also check to see if the innter shaft and the other parts are lubed up well enough with a teflon lube. That would be my advice anyways
