Add a strip of carbon fiber to the elevator and that should make it stronger. You need some pretty big tires to roll off grass, but then they won't fit in your retract bay. Hold a little up elevator on take off unit the tail comes up then gradually lift the plane off the field. Sounds like a good setup. I had the same setup in my P40 until it caught fire
