ORIGINAL: kryptonite
If you are considering a stick, I suggest going with the Ultra Stick over the Super Stick (cheap covering ) or the Big Stick ( tricycle LG ). I find the sticks more fun than the low wing sports trainers - their absolutely neutral flying characterics make for easy aerobatics. The constant chord wing prevents nasty tip stalls and the 0-dihedral symmetrical airfoil makes them fly inverted just as well as upright and rolls are nicely axial. It also has an airfoil that is just right - allowing you to have a great balance between stability and speed. If you decide on going the low wing route, check out the Hangar 9 Pulse XT as well. Its an excellent design by Mike McConville with great flying characteristics and modern, easy bolt-on design - so less work putting together.
Exept for the "cheap covering" what will be the difference between the ultra and the super stick from H9?
Because one of my friend have the solo stars and the covering seems to be ok (so long, at least)
