RCU Forums - View Single Post - Trex 600 battery question
Old 10-03-2007 | 06:54 PM
Old Sloppy's Avatar
Old Sloppy
Default RE: Trex 600 battery question
ORIGINAL: ea01bg
2200 mah 20C
2200 @ 20C = 44 amps.
You know @ 44 amps expect 50 cycles on that battery, no more.
How many amps does a 600 XL motor draw? ( I thought they came with a 75 amp ESC)
I think if it even works, it will over stress your cells.
You could use 4 batteries in a 6s2p configuration, then you would have 88 amps on tap. ( I dought a stock motor draws near that much)
the battery will work, in the proper configuration...
Harry S.
