ORIGINAL: frenchie79
I put a Magnum 46 in the plane. Had it in a box and wanted to use it-so buy a kit! you no the story. On the test stand i was running 16050 on a 9x7 APC, 15870 with a 9x8 MAS. You don't think thats to high. What do you think it will unload at.
Those RPMs are ideal...... and indicate a good running engine.
For flight, richen up the engine about 600 rpm down from those peaks before launch.
