RCU Forums - View Single Post - C/L scale handle
Old 10-06-2007 | 08:04 AM
R8893
My Feedback: (20)
Default RE: C/L scale handle
Jerry,
I have built 8 twins to date and three are control line. I use one channel for the throttle. If one engine is a little stronger than the other you can mount it on the inboard side. Some R/C guys use two throttle channels, but with a computer transmitter so that they can match the rpm's throughout the throttle range. I don't think i t is worth the effort. I sure would not use two sticks to control two unmixed channels on a C/L model. Any mistake where you moved only one stick would be instant demise of your model. I am like Fred in that I use a JR radio in the direct servo control mode. It is very easy to set everything up for your left hand; my Hs129 has throttle, flaps, retracts, and bomb drop. I use mine with a neck strap.
Chuck
