RCU Forums - View Single Post - Changing my tailboom
Old 10-06-2007 | 09:47 AM
[]TEX[]
Default RE: Changing my tailboom
You'll have to use a soldering iron to remove the wires from the tail motor. There is a screw holding the tail case on, remove that and pull it off. THe boom will come out of the airframe once you loosen the screws. I am sure the manual describes this process.
