RE: Truggy vs Buggy?
2d - I used the grey mugen springs (the ones for their big bore shocks). They are softer then the xray light blue springs (which are softer then the dark blues). I am running losi 50 wt oil all around with 1.3 drilled pistons front and 1.4 drilled pistons rear and this is the best setup I have tried yet. Also, you do not need near as much preload with these springs, since they are longer. The shocks feel much better with 4 hole pistons then they did with the 2 hole ones. I did check out some kyosho big bore shocks the other day and they are like butter...man, they felt good. I think I am gonna try the KMW big bores though...heard nothing but good things about them (brass pistons to boot..no plastic anywhere!)
also, what shock boots are those (losi 8ight's?)
