RE: NEED HELP WITH RUSTLER
yes very bad never ever lean it til theres no smoke from the exhaust. put the settings back to factory and before you start it take a heat gun or hair dryer to the cooling head for a little bit to heat the engine up a bit. then when you start it up give it a very slight amount of gas with the wheels off the ground for a few secs and then go on with break in. hope this helps
