RE: getting my gears perfect
Both sets of advice sound correct. Its just that its for 2 different settings. The mesh between the spur gear and pinion gear can be set with a piece of paper. The slipper clutch should be set by tightening the adjuster nut till the spring is compress all the way, then backing off about a quarter turn.
