Help with making a THR to ELEV mix, 9C
I'm trying to create a mix (that is on all the time = switch assignment is "null") that will cause the elevator to lower a little as the throttle is advanced.
It appears to me it should be as easy as going to one of the mixes in the Advanced menu and setting the throttle as master and the elevator as slave. I've tried that and nothing happens.
Is there a trick to this I don't know?
Thanks for the help in advance.
